06-17-14, 10:57 PM
Part 1:
While I will focus on the 1966 Dodge Coronet 500 models for many of the parts that I will talk about in this thread, I will cover the codes for front bucket seats with Black vinyl seat covers on most all of the 1964 through 1974 models as well so that you can understand how these interior trim color codes work. Also please keep in mind that much of the information covering other interior parts for the 1966 Coronet 500 models will be similar for other model years. Colors and color codes will change from model year to model year, but the three to four digit color codes can be decoded in the same way for whatever car you're working on from 1964 through 1974 model years. The model years prior to 1964 have different style interior trim codes, so to keep things less confusing, I will not cover any model years prior to 1964 here. To also keep things less confusing, I will use the interior trim codes for cars equipped with Black vinyl bucket seats in all of my examples below.
1964 Through 1974 Interior Trim Code Location On Your Cars Fender Tag:
The number of digits used for interior trim codes from 1964 through 1974 will vary from three to four digits depending on the model year. This code will be stamped on your cars fender tag in the following locations.
1964 - 3 Digit trim code is stamped on line 1 under "TRM' stamped on line 2. (line 1 is located at the bottom of the fender tag closest to the fender)
1965 - 3 Digit trim code is stamped on line 1 under "TRM' stamped on line 2. (line 1 is located at the bottom of the fender tag closest to the fender)
1966 - 3 Digit trim code is stamped on line 1 under "TRM' stamped on line 2. (line 1 is located at the bottom of the fender tag closest to the fender)
1967 - 3 Digit trim code is stamped on line 2 under "TRM' stamped on line 3. (line 2 is located on the second row from the bottom of the fender tag closest to the fender)
1968 - 3 Digit trim code is stamped on line 2 under "TRM' stamped on line 3. (line 2 is located on the second row from the bottom of the fender tag closest to the fender)
1969 - 3 Digit trim code is stamped on line 2 (line 2 is located on the second row up from the bottom of the fender tag closest to the fender)
1970 - 4 Digit trim code is stamped on line 2 (line 2 is located on the second row up from the bottom of the fender tag closest to the fender)
1971 - 4 Digit trim code is stamped on line 2 (line 2 is located on the second row up from the bottom of the fender tag closest to the fender)
1972 - 4 Digit trim code is stamped on line 2 (line 2 is located on the second row up from the bottom of the fender tag closest to the fender)
1973 - 4 Digit trim code is stamped on line 2 (line 2 is located on the second row up from the bottom of the fender tag closest to the fender)
1974 - 4 Digit trim code is stamped on line 2 (line 2 is located on the second row up from the bottom of the fender tag closest to the fender)
1964 model year - 3 digits placed in this order, capital letter, number, capital letter.
Example - interior trim code P4X
P = trim grade, P = premium trim grade
4 = seat material used and seat type, 4 = vinyl seat covers, front bucket seats
X = trim color, X = Black
1965 model year - 3 digits placed in this order, capital letter, number, capital letter.
1966 model year - 3 digits placed in this order, capital letter, number, capital letter.
4 = seat material used and seat type, 4 = vinyl seat covers, front bucket seats (for the following 1966 models plus any others in 1966 with factory installed bucket seats)
BP - Barracuda models
LP - Dart GT models
RP - Satellite models
WP - Coronet 500 models
XP - Charger models
DP - Monaco 500 models
PP - Sport Fury models
All Chrysler models equipped with factory bucket seats
1967 model year - 3 digits placed in this order, capital letter, number, capital letter.
Example - interior trim code P6X
6 = seat material used and seat type, 6 = vinyl seat covers, front bucket seats
(for all 1967 models equipped with this style of factory bucket seats)
1968 model year - 3 digits placed in this order, capital letter, number, capital letter.
(for all 1968 models equipped with this style of factory bucket seats)
1969 model year - 3 digits placed in this order, capital letter, number, capital letter.
(for all 1969 models equipped with this style of factory bucket seats)
1970 model year - 4 digits placed in this order, capital letter, number, either double capital letters, or combination of capital letter and number.
Example - interior trim code P6X9
(for all 1970 models equipped with this style of factory bucket seats)
X9 = trim color, X9 = Black
1971 model year - 4 digits placed in this order, capital letter, number, either double capital letters, or a combination of capital letter and number.
(for all 1971 models equipped with this style of factory bucket seats)
1972 model year - 4 digits placed in this order, capital letter, number, either double capital letters, or a combination of capital letter and number.
(for all 1972 models equipped with this style of factory bucket seats)
1973 model year - 4 digits placed in this order, capital letter, number, either double capital letters, or a combination of capital letter and number.
(for all 1973 models equipped with this style of bucket seats)
1974 model year - 4 digits placed in this order, capital letter, number, either double capital letters, or a combination of capital letter and number.
(for all 1974 models equipped with this style of bucket seats)
Interior parts such as the headliner, door panels, armrest pads, kick panel covers, seat covers, carpet and other similar related interior parts are found in the Factory Parts Book in the "Interior Trim" sections. In the 1966 Factory Parts Book these Interior Trim sections are broken down into separate sections for "Plymouth", "Valiant", "Dodge", "Dart" and "Chrysler / Imperial" models.
Diagram #1: 1966 Factory Parts Book - Interior Trim - Dodge Section - Page 1 (Please Read Carefully!)
![[Image: 1966FactoryPartsBook-InteriorTrim-DodgeS...-Page1.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/1966%20Factory%20Parts%20Book/1966FactoryPartsBook-InteriorTrim-DodgeSection-Page1.jpg)
Please note on the above picture of page 1 of the "Dodge" section of the "Interior Trim" that the part numbers for many of the interior parts contain a combination of letters and numbers to help identify specific colors for each part rather that being made up of all numbers like most mechanical and body parts are.
Diagram #2: 1966 Factory Parts Book - Interior Trim - Dodge Section - Page IT 133 - Seat Cover Information - For 1966 Coronet 500 2 Door Hardtop Models (Please See Diagram #4 Below For Letters and Numbers Explanation Used on Diagram #1)
As shown in the diagram below, there were six interior colors available for the 1966 Coronet 500 2 door hardtop models. These same six colors were also used for the 1966 Coronet 500 convertibles and the 1966 Chargers as well. As mentioned, these interior trim color codes will be stamped on your cars fender tag.
The interior trim codes for the six colors are as follows. (also please see diagram #3 below)
Blue = interior trim code P4D
Red = interior trim code P4R
Tan = interior trim code P4T
White = interior trim code P4W
Black = interior trim code P4X
Citron Gold = interior trim code P4Y
![[Image: 1966FactoryPartsBook-InteriorTrim-DodgeS...eIT133.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/1966%20Factory%20Parts%20Book/1966FactoryPartsBook-InteriorTrim-DodgeSection-PageIT133.jpg)
Diagram #3: 1966 Factory Parts Book - Interior Trim - Dodge Section - Page IT 159 - Interior Trim Color Codes For 1966 Coronet 500 2 Door Hardtop And Convertible Models. 1966 Chargers Also Use These Same Codes Even Though The Charger Isn't Included On This Diagram. (the codes for these models are marked with a hand written * on the left side of the page)
![[Image: 1966FactoryPartsBook-InteriorTrim-DodgeS...eIT159.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/1966%20Factory%20Parts%20Book/1966FactoryPartsBook-InteriorTrim-DodgeSection-PageIT159.jpg)
Diagram #4: 1966 Factory Parts Book - Interior Trim - Dodge Section - Specific Interior Parts Codes - Page IT 157 (Used To Explain The Seat Cover Information Diagram #1 Posted Above. This Same Diagram #4 Is Also Used To Explain Other Interior Parts That Are Discussed In Part 2 Below (Please Read This Information Carefully!)
![[Image: 1966FactoryPartsBook-InteriorTrim-DodgeS...rIT157.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/1966%20Factory%20Parts%20Book/1966FactoryPartsBook-InteriorTrim-DodgeSection-PagrIT157.jpg)
Additional Reference Material:
One other reference book that I'd like to mention below is my purchased copy of the "seventh edition" of the "1966 - 1968 Chrysler Corporation Production Option Code Book" authored by Mr. Galen Govier. This book is very helpful regarding all of the available options for the 1966 through 1968 Dodge, Plymouth, Chrysler and Imperial models and also gives lots of information regarding exterior and interior paint color codes, as well as interior trim, vinyl roof, convertible top and exterior stripe color codes for all of the 1966 through 1968 models. Mr. Govier still sells this book on his web site and it is also available on Ebay from time to time.
![[Image: ChryslerCorporationProductionOptionCodeB...tCover.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Mopar%20Decoding%20Information/ChryslerCorporationProductionOptionCodeBook-1966-1968-FrontCover.jpg)
![[Image: ChryslerCorporationProductionOptionCodeB...mCodes.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Mopar%20Decoding%20Information/ChryslerCorporationProductionOptionCodeBook-1966-1968-InteriorTrimCodes.jpg)
PLEASE SCROLL DOWN BELOW FOR THIS SAME INTERIOR TRIM CODE INFORMATION FOR THE 1969-1971 CARS AND FOR THE 1972-1974 CARS THAT I'VE ADDED ON 7-5-2014.
LP - Dart GT models
XP - Charger models
![[Image: ChryslerCorporationProductionOptionCodeB...tCover.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Mopar%20Decoding%20Information/ChryslerCorporationProductionOptionCodeBook-1969-1971-FrontCover.jpg)
![[Image: ChryslerCorporationProductionOptionCodeB...mCodes.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Mopar%20Decoding%20Information/ChryslerCorporationProductionOptionCodeBook-1969-1971-InteriorTrimCodes.jpg)
![[Image: ChryslerCorporationProductionOptionCodeB...tCover.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Mopar%20Decoding%20Information/ChryslerCorporationProductionOptionCodeBook-1972-1974-FrontCover.jpg)
![[Image: ChryslerCorporationProductionOptionCodeB...mCodes.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Mopar%20Decoding%20Information/ChryslerCorporationProductionOptionCodeBook-1972-1974-InteriorTrimCodes.jpg)
