Full Version: Board Changes
Made the following changes to the Tech Section part of the board:
1) Re-arranged the forum locations so they flow a little better.
2) Added a new section called Modernize Your Coronet. If you're looking for info on adding modern equipment to your car, or are in the middle of upgrading your Coronet post your progress here.
3) Added a new section called Tech Archives. This section is where Piper and myself will be putting in posts from the Tech Section that have good information. Rather than have them fall into the ether at the bottom of the forum, they'll remain at the top. Sort of like a "sticky thread", but just in a seperate location so the regular forums don't get clogged up. To keep the section from becoming a discussion forum like Tech is, this is a read only portion of the board.
Looks great guys!!!
