Results 1 to 4 of 4
Thread: Original fuel line 50 dodge
  1. #1
    Senior Member 50net's Avatar
    Join Date
    Jan 2013
    Location
    La
    Posts
    101
    Just recently changed fuel system from pump to tank.when i removed old line, area from rear axle to tank had spring on line.like bending springs.i couldnt remove due to rust.so i slipped rubber hose on new line at area.does anyone know if this was original from mfg time or someone left springs on from old changing?
  2. #2
    Hoosier Daddy Racer Brown's Avatar
    Join Date
    Jan 2013
    Location
    Northern IN
    Posts
    2,489
    Yup, that's factory, my R/T had them on, when I restored it I was able to order a new box of it from Chrysler, that was sometime ago, i don't have a part# now. This protected the line from anything that got thrown up agaisnt the line.
  3. #3
    Join Date
    Jan 2013
    Location
    La
    Posts
    101
    Racer,thanks for the info.since was only over axle and bend to tank thought it was used to make bends and just left on
  4. #4
    Join Date
    Jan 2013
    Location
    Northern IN
    Posts
    2,489
    ...ans certian portions of the brake lines too.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
